Originally Posted by Christ
I a mannerof speaking, the only way to remove from one is to give to the other, and vice versa... In other words, if you are reducing drag in one vector, you're increasing thrust in the opposite vector. It's still net negative. Semantics.
yeah, the same way deceleration is actually acceleration in the opposite direction. it isn't really the same thing but has the same effect
