Old 03-30-2011, 01:40 PM   #16 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Joenavy85 View Post
i understand that fluid dynamics is very broad, but the spoon demonstration is hydrodynamics not aerodynamics, the flow of water is completely separate from surrounding air, that is more of a demonstration of surface tension.
I've tried it with pressurized air at work - it still works when you use air instead of water.
