Thread: Wai
Old 03-30-2011, 04:04 PM   #20 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
Originally Posted by MGB=MPG View Post
where can i find a durable light weight cable controlled 2 inch pipe mixer valve ? any help?
One solution might be an 80's toyota carbed vacuum controlled flapper (vac motor) that uses manifold vacuum controlled by a sensor located in the bottom of the air filter housing. This setup is supposed to keep the intake temp at around 100F. I'd guess that you could move the sensor around so that you might be able to control your IAT in a range from under 100 F to over 100F? If the sensor was in ambient air it would try to raise the IAT temp under any conditions other than 100F ambient. If it was mounted on a coolant hose...it would only raise the IAT temp until the engine was halfway warmed up?
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
