Thread: Hello all EMs.
Old 05-02-2008, 11:03 AM   #33 (permalink)
Loory
Canada EM member
Loory's Avatar
Roguee - '09 Nissan Rogue SL AWD
90 day: 27.49 mpg (US)
trikkonceptz
All right for you tire press.
About the roof rack, there's a post about it somewhere, let me see, it' at:
http://www.giantmosquito.com/vibe/roofrackremoval.html
It's the only page i found.
anyway i found it quite easy finally i poped up the 4 corners by pulling in a upward direction (for the rear caps, i firstly disengaged the small tab from the front exterior side, see the yellow circle at the link page above in step 1.
After that i unscrewed the two bolts per sides and at this point a had no choice but pulling the rack up to unsnap the 3 fasteners in between (they broked for me but we can purchase some more) and that's it.
Good luck.
Daox
Thanks for the infos ! I will get my tires harder pretty soon, i will without a doubt get a better FE because of that.
Great that your winter tires are still in great shape, how many milles have you done on them at 50psi ? What is the model and size tires you have for winter and summer, just curious.
Thank you for the "How to setup your mileage signature" page link, i didn't know it was a signature.
