Thanks! i've already ordered some coroplast to block off the lower grill, the under side of the front bumper, and foglights as well as the hood vents and sidescoops, also to replace the factory air dam with a slightly larger one along with a MPGuino to record the changes these mods make.
"If you do things right, people aren't sure if you've done anything at all."
