Originally Posted by gabi
the upper camber of the body accelerates the flow,hence dropping the pressure there in compliance with Bernouli's Theorem.The atmospheric pressure under the structure pushes the structure upwards in an attempt to reach equilibrium pressure but cannot penetrate the impermiable membrane so it remains there until power is pulled,pressure equalizes and lift goes to zero.
There is no accounting for the external horsepower necessary to created this effect.
