Old 04-01-2011, 10:30 AM   #13 (permalink)
Daox
T nuts would be another good choice. I chose the rivet nuts because they're aluminum and if I wanted to bond the two metals together I figured aluminum to aluminum would be easier than steel to aluminum. They also stuck up a bit further which gives you a bit more room to play with fastener length.
