There is a product called "Alumaloy" which lets you braze aluminum parts together. Used it once to make a questionable plenum for a kart. It held up for quite a while.
I swear I saw a set of wheels on a Prius in the parking lot here at work where there was a trim ring that would rotate to block off airflow through the wheel. Anyone ever seen them?
Don
