Yeh there was a pwm of 1.96khz. I had 99% soc at the time. The change to 20% in setup mode made no difference that i could see. I'll have a look at the code myself but it's taking a while to catch up
That said it did work yesterday as i mentioned but then reset itself to full. I do suspect the fuel gauge computer in the dash is partially to blame. I'm looking out on ebay for an old "smiths" type fuel gauge that i could mount in a dash pod and use for testing. Sadly , they command a high price nowadays due to popularity in kit cars.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
