Old 04-01-2011, 08:52 PM   #40 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Hello -
More details on the motor/alternator :
2012 REGAL TO OFFER NEW eASSIST FUEL-SAVING TECHNOLOGY
http://www.buick.com/content/dam/Bui...al_eAssist.pdf
The eAssist power pack contains the lithium-ion battery pack, the integrated power inverter and 12V power supply. It is located in a compartment between the rear seat and trunk; and it is surprisingly compact and lightweight, weighing only about 65 pounds (29 kg). Trunk space is slightly reduced when compared with 2011 models with the four-cylinder/six-speed powertrain, but still offers 11.1 cubic feet (314 liters) of storage. A quiet electric fan cools the power pack, drawing air from a vent located in the package tray, behind the rear seat.
The eAssist systems electric induction motor-generator is mounted to the engine in place of the alternator to provide both motor assist and electric-generating functions through a unique engine belt-drive system. The induction motor-generator is a high-performance, compact induction motor that is liquid-cooled for increased performance and efficiency.
Next-generation six-speed
The eAssist system works with Regals direct injected 2.4L Ecotec four-cylinder and next-generation six-speed automatic powertrain combination. In the Regal with eAssist, the engine is rated at 182 horsepower (136 kW) and the next-generation Hydra-Matic 6T40 takes transmission technology to the next level with features designed to enhance powertrain efficiency.
Significant internal transmission changes to clutch controls and hardware provide reduced spin losses while improving shift response and time. The added electric power provided by the eAssist system allows for higher gearing to improve steady state efficiency without impacting acceleration performance or driveability. The systems ability to provide some electric assistance at cruising speeds allows the driver to accelerate lightly or ascend mild grades without the transmission downshifting.
An auxiliary, electric-driven transmission oil pump is added to the 6T40, which keeps the transmission primed and the fluid flowing when the engine shuts down at a stop. That keeps the transmission ready to perform when the driver accelerates, for a seamless, uncompromised driving experience.
Soooooo, if you're a featherfoot, you can keep the car from downshifting.
CarloSW2
American Solar Energy Society
