Old 04-02-2011, 11:32 AM   #667 (permalink)
eimix
Originally Posted by spfautsch View Post
...checksumming, formatting data, sending to lcd, handling button presses, etc...
make sense - i will try to put in next release.
With standards, it all comes down to wording. I don't have anything to go by, but I would imagine there's language in there along the lines of "as much as" or "no more than" or something to that effect. Probably the best way to handle reinit as quickly as possible would be to add a self-learning routine, but that would be a lot of program space for little realized utility.
this will not take much space, i will attemt to make this too, next week.
What build version are you currently using, and have you ever gotten reinit to work? I almost had it working last night, but something is failing around the end where supported pids are queried.
In my car (VW jetta 2001 1.8t) reinit works normaly, i do not know why do u get problems
I use 190 (it will be 190 some day)
and if you get errors while requesting first pid (about supported pids) is your "lastRcv" initialized? (dumb question, but i have to ask it)
