Old 04-02-2011, 11:45 PM   #4 (permalink)
ATaylorRacing
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
When raising turbo boost in the 80-90 turbo Dodges we'd put a resister into the map sensor wire so that it would not see how much boost we werre running and would not shut off the motor at about 14 psi....BUT, to run more than 14 psi we'd stick some extra cold start fuel injectors from a VW or Saab and have them hooked up to Hobbs pressure switches so as each higher level of boost was hit another injector would be turned on so there would be no leaning out and parts melting/breaking. A guy named Paul Smith had a woodie Dodge Caravan with a basically stock motor running in the low 12s while using a bunch of those injectors and pressure switches used in series!
42 time NHRA/IHRA drag race champ
05 SRT4-12.17@117 mph on DOTs-31.0 mpg-SOLD
96 Geo Metro-3 banger-60.1 mpg-SOLD
95 BMW M3-13.41 @ 106 mph-31mpg-SOLD
77 Chevy Monza with 350/350-FOR SALE
84 Horizon-1880 lbs-29 mpg
95 Neon-43 mpg
99 Z28-10.80 @ 127 mph-27.1mpg
2011 Prius-62.1 wife's
