If you're just comparing chemical energy, you need to also add in the weight of the oxygen from the air that's going into the chemical reaction, which IIRC is about 4:1 by weight. So if you had to carry around your own oxygen instead of getting from the air, you'd need (I think) about 35 lbs/gal.
