Old 04-03-2011, 03:16 PM   #43 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by ktaylor View Post
Oh yeah. Makes sense. I can't wait till the summer, although most of my trips are going to be really short, (local work) as compared to my hour and a half highway commute.
The Buick is a highway car, in town it isn't happy. It is possible if the speed limits are right and your stops are far enough apart to get around 25-28mpg in town but if every block is a stop, be ready for being down in the dumpster.
I will be bombarded with negativity after posting this, but...
Something I did do to keep the FE in town higher than it should have been was EOC up to stops, on the Buick that will raise your FE fairly well. (but may be difficult to measure) I didn't do it a lot or for short off periods, but I did it whenever I expected a fairly long coast or a fairly long stop. The 98 Buick like all newish Front Wheel Drive GM products can be dingy pulled motor off for up to 100miles (some models 250miles) up to 50mph. This means you can likely get away with EOC, just check your manual and the internet for your year and model. On autos it is best before EOC to let off the gas, shift to neutral, let the GPH measure on the scanguage fall a bit then shut off. Remember though that you can't accurately measure your gains without an injector kill because mileage won't be counted for much of this process.
Also I don't recommend you just go ahead and do the above, it takes a lot of practice, skill and the right conditions to do the above safely. It will become hard to steer (if you don't understand and expect it) and you only get about 3 power braking actions. (I can still stop without power brakes by leaning into it a bit)
That said I can steer my full size dodge ram truck without power steering with motor off (takes a bit of elbow grease).
So after a bit of research, a bit of practice on a straight unpopulated set of road to see how your car behaves, this technique can be sparingly used in certain situations. In my case I have my trips mapped out in my head and certain areas get the EOC treatment because I have determined there is minimal if any risk, there is a decent gain (I can coast upwards of a mile in 1 specific location (doing 20mph the whole way) and no traffic) and usually because the spot happens to be consistant in that I should EOC due to the way that paticular intersection and lights behave.
If you find yourself driving a paticular set of roads with a specific set of traffic and behaviors learn to actively think about the best way of getting through the areas with the least gas, perhaps there is a long downhill section with minimal lights and traffic and spots where you need to set at lights an extended period. Or perhaps the lights behave a specific way and driving a bit slower or coasting engine off so you don't hit them red might work for you.
With practice I think you can do 2-4 mpg better than your current average, but it takes some concentration and planning.
Good Luck
Ryan
The Following User Says Thank You to rmay635703 For This Useful Post:
ktaylor (04-04-2011)
