Originally Posted by Varn
Since I made my hood splitter I have been rewarded by getting 50 mpg over 500 miles. My previous best was the last tank was 47 mpg.
From what I have heard the newer diesels are more efficient than my 1986 engine is.
It's as good as my 20 years younger car - as far as fuel consumption goes anyway.
The best TDi's from a FE point are the mid to late 1990's 1.9L engines with 90 hp - at best mated to a light car.
I am thinking about aerodynamics and don't believe the scenario of that the front is good enough and the name of the game is entirely at the back.
Have you seen the diagram with the streamlined brick ?
You gain by far the most by streamlining the rear end, even if the front is still brick-shaped.
You can gain a little bit by streamlining the front.
Streamlining both ends gives the highest gains - but it's not that much better than with only the rear.
So, modding the front is going to be less time/energy/cost effective than modding the rear.
But obviously, it'll still help.
Guess I have to try for 55....
Why not
