Originally Posted by Arragonis
Why not make it simpler. Make a mechanism like a ski-lift - two wheels with a loop of wire or string between them. If you rotate one wheel the string will move between them. Then suspend the light from a cord attached to the string. When it reaches one end it will turn and then go back again.
Something like this :
The only thing you would need is a rotating mounting thing for the light so that if it has a cord, the cord doesn't twist.
I can't do that because;
1) the electrical wire would get tangled
3) the light is wide and can't "turn" as it would hit the top canopy.
Basically, how could I copy a light mover? they use DC motors and limit switches... I just want to copy the circuit diagram (since they are so expensive to buy lol)...
LightRail 3.5 IntelliDrive 10 rpm Kit | LightRail Website
