Old 04-04-2011, 06:51 PM   #17 (permalink)
3dplane
3dplane's Avatar
14 Mirage - '14 Mitsubishi Mirage DE
90 day: 68.74 mpg (US)
The 60 lead acid batteries used in Dave Cloud's Dolphin weigh 33 pounds each, so the total is 1,980 pounds. He has driven it ~200 miles, and those batteries are used... I think that is about 30kWh, so a little less than 1 gallon equivalent at 1 ton.
The bottom line is I think your initial weight estimate is about 2X too high?
I think you are right it's probably fair to use the 2000lb number. I was compensating for peukert by going 2x the weight.
