Old 04-04-2011, 11:04 PM   #9 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Even tho your alternator might be able to put out 135 amps, the rest of your wiring might not be able to handle that many amps and you would need to beef up your ground straps as well as clean all of the connections, otherwise you are going to fry something, or set your car on fire.
also check the fuses, your alternator might be fused at 60 or 80 amps.
