Originally Posted by flores
I'm a bit confused on how to place the busbars on the 500A controller.
In pictures I see sometimes the busbar ends all on one side and sometimes the middle busbar is on the reverse side of the case.
Is there a special reason for this difference? Or is it just personal preference? Or a difference between rev D and C?
thanks
Which end they stick out is your decision. Some layouts of the car work better 1 way instead of the other. It does not matter.
If you want, you can use a longer B+ bar so you have the B+ and B- on one side, then B+ and M- on the other. I dont think ive seen one like this yet though....
-Adam
