Old 04-05-2011, 07:46 PM   #8 (permalink)
mystere485
Barges Ahoy!
The Black Car - '93 Honda Civic Del Sol si
90 day: 33.68 mpg (US)
The Benz - '70 Mercedes-Benz 220d
90 day: 33.13 mpg (US)
acura - '98 acura EL Premium
90 day: 29.91 mpg (US)
Send a message via AIM to mystere485
Originally Posted by BrianAbington View Post
I have seen air bag suspensions on these cars.
You can get some good improvements from aero work but it is hard to make those ford V-8's efficent.
Have you considered an engine swap?
I have thought about an engine swap, but this car will be multi-purpose and i would still like tow capabilities for a small trailer or even a car dolly.
Air bag suspension, i thought about it. For towing purposes but as for lowering i hadn't. After market systems do not appear to be to cheap. How hard would it be to retrofit a factory system?
Originally Posted by UFO View Post
What fuel mileage does it currently return? What transmission does it have? Sounds like if the mods go well, you could have a very economical yet comfortable road trip vehicle.
He said it was getting 800(497.096 miles) or so kms per tank @20 gal=24.5 mpg roughly, mind you this was never less than the speed limit...atleast 10km above. As far as i know it is the AOD because it is a 1994 model with the 4.6L and the 3.08 rear. Mileage is high at 200k miles, but other than needing routine maint. its good to go.
Originally Posted by Nevyn View Post
Flares would increase frontal area, which is bad. Full skirts would be better. What year is the car, what engine is in it?
The only problem is how much it curves in at the bottom... I was trying to make any changes as factory looking as possible. Would a side skirt(on the rocker) that extends out far enough to have a surface face on par with the face of the wheel do the trick? Instead of just hitting the tire and going wherever...?
