In this case I think the problem is that after aeromods a 4.6L engine running at ~1500rpm will still be in a crummy portion of the BSFC map (~350+g/kWh). In order to get into a nicer portion taller gearing (~1000rpm@60mph) or a smaller engine would probably be required.
