Interesting smoke around the beetle. A top down view would be interesting considering the external fenders.
Nice thing about the multiple lines is that you can see compression by noticing the spacing of the lines at the front of the car
Since lowering the windshield might be prohibitive filling in front of there might be a start to lower the pressure over the roof of car. The smoke trail is moving upward at about 20 degrees.
On the 86 jetta the trunk lid is pretty high but still might be a bit low to be ideal. Thankfully it is squared and not rounded like the early model vw. unfortunately the front of the jetta is also very square. The hood angle is 7 degrees.
– Noah Webster, 1787
