Old 04-08-2011, 03:36 AM   #676 (permalink)
eimix
only one of #define ELM or #define ISO_9141 could be defined. other one has to be commented. if you use ELM, others has to be commented.
and for now it looks that you should comment "#define useECUState" and do not use it.
i use ISO only, i do not have ELM. btw you should try some older versions until somebody confirms that current version works with ELM fine.
