Old 04-08-2011, 10:03 AM   #43 (permalink)
mystere485
Barges Ahoy!
The Black Car - '93 Honda Civic Del Sol si
90 day: 33.68 mpg (US)
The Benz - '70 Mercedes-Benz 220d
90 day: 33.13 mpg (US)
acura - '98 acura EL Premium
90 day: 29.91 mpg (US)
Send a message via AIM to mystere485
Originally Posted by comptiger5000 View Post
Keep in mind, he's shooting for 40mpg highway and doesn't care much about city. Thus, taller tires, while they can hurt city mileage, shouldn't be a problem on the highway, as they're maintaining a relatively constant speed.
this is true, it will be used for highway driving, 2000+ km trips at a time.
Originally Posted by Big Dave View Post
The gas-pig 4.5L V-8 has to be replaced with a diesel.
The slushbox has to be replaced with a stick.
Those two (plus some moderate hypermiling) should get the car over 30.
there are members getting 24-25 mpg with no mods in their crown vics. Ok, so we use that as a base. First mods:
LRR tires and light weight rims
Replace the engine fan and clutch with an electric assembly
underdrive pulley
build a front air dam and belly pan
block off the bumper intakes and replace the grille with 1992 style model
HAI
tune-up, oil and trans fluid change
get rid of the spare, jack, replace the front bench seats with newer buckets
Replace rear side and quarter glas with plexi
lower car 2 inches
If feasable, swap intake and exhaust manifolds and switch to PI heads.
should these mods not get me to 30 mpg?
