Originally Posted by eimix
i use ISO only, i do not have ELM. btw you should try some older versions until somebody confirms that current version works with ELM fine.
Thanks.
I will both look back at comments in this thread, and at previous code versions, to decide which the last known "good" ELM version is.
I will also make at least a small effort to continue to understand ELM issues in the current version.
Then I'll post with what I find.
