Old 04-08-2011, 12:57 PM   #45 (permalink)
comptiger5000
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
mystere - The stuff you mentioned (although I agree with Christ, skip the underdrive pulley), especially if combined with taller gears, will get you into the 30s. I would think that if you can gear it tall enough, those mods alone could see 35 or so.
If it's a serpentine belt, ditching the PS and A/C might require bypass pulleys to make everything work properly, and still spin the water pump the correct direction. I'm sure a pulley is available for the A/C, but the PS may or may not be. Plus, in a big car like that, I'd want to do a little testing before just dumping the power steering, especially if it's a recirculating ball steering box, as they can be damaged by lack of fluid flow unless it's meant to be used as a manual steering box.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
