So your saying the factory 10* BTDC is where I should keep it?
I already had to remove the cats and replace with an off road H pipe (the original cats were making the carpet really hot!). But after I replaced them it seemed to run alot better.
"If you do things right, people aren't sure if you've done anything at all."
