Its not my intuition, and I wasnt asking a question... Its pointing out that there are inconsistencies in digit math when using percentages compared to integers.
Intuition would tell you that since 11 is 50% of the diff between 10 and 12, and the respective solutions for ten and twelve were 50 and 60, the solution for 11 should be 50% of the difference. However, average would-be mathematicians haven't accounted for the scaled increase when using the percentile as an intuitive route to check a solution.
600/11 is, in fact, 54.54e, just slightly less than 50% of the difference between the solution for 600/10 & 600/12, even though 11 is exactly 50% of the difference between 10 and 12.
