Old 04-10-2011, 02:55 PM   #1 (permalink)
ngrimm
Old bed liner for belly pan
For my black Bronco II 4x4 I would like to add a front belly pan but haven't found anything cheap or strong enough to cut up. Then I noticed there are lots of used plastic (abs?) bed liners on CL for $50 and up. There would be a lot of material left over maybe even for an air dam etc. Btw, I'm not expecting miracles for mileage but since I have ordered an Mpguiino or whatever it's called I can do some ABA tests. All of the bed liners I have seen have ribs on the bottom so I was wondering if that would be bad for use as a belly pan. Thank you.
The Following User Says Thank You to ngrimm For This Useful Post:
Nevyn (04-15-2011)
