the material was coroplast with scrap wood as a support. the design was to be a splitter right where the front grill opening is then taper off to a regular air dam flat i thought it would be better to scoop more air in a smaller hole than make the holes larger and just do a regular air dam.
SCANGUAGE IT REALLY WORKS
