Old 04-11-2011, 01:30 PM   #3 (permalink)
ngrimm
Thank you. I think I'll give it a try. The underside of this Bronco looks pretty "unclean" to me due to the ifs. The front differential is nearly a flat surface hanging down 12" below the frame. At least the old straight axle 4x4's had a rounded housing. Would having a belly pan that starts at the existing bumper/spoiler and angles down to cover the axle work instead of adding an air dam? I've been reading all I can on this forum for about a year but don't recall seeing that discussed.
