Old 04-11-2011, 07:53 PM   #12 (permalink)
Bill in Houston
Originally Posted by COcyclist View Post
My Mk IV has a bunch of 15mm plastic plugs in the underbody. I keep staring up at these on my back trying to come up with a way to attach my belly pan without drilling into the sheet metal.
You could screw into them, OR remove them and put in an appropriately sized expanding rubber freeze plug and put the belly pan material between the big top washer and the nut. You might want another washer in there.... Or, I'd probably use the freeze plugs to mount some simple aluminum cross-pieces and then attach the belly pan to the aluminum.
