Old 04-12-2011, 01:21 AM   #4 (permalink)
jamesqf
Originally Posted by War_Wagon View Post
Driving it around the yard where it's stored seems ok, but I could not get the feature where the 1.0L shuts off at a stop with the clutch in to work.
Autostop doesn't work when the engine is cold. Coolant temp needs to be (my experience) above 140 in summer, higher in winter. There's some fairly complex logic in there: you also have to get above a minimum speed, have shifted at least into second, the climate control needs to be off...
The charging lights never came on either while driving, though I never got over 30 km/h. I know the display itself works as the pre-start cluster check lights everything up just fine.
What's the battery charge indicator show, full, empty, or part? It won't usually do charging at low speeds...
