Old 04-12-2011, 04:00 PM   #11 (permalink)
War_Wagon
5 Gears of Fury
War_Wagon's Avatar
Spunky - '90 Honda Civic CX
90 day: 35.56 mpg (US)
Ok, thanks for the IMA info. When nothing was showing any charging going on I was starting to worry. I am still going to assume that the IMA will need to be rebalanced/replaced and get some money set aside for that - that way if it does not need to be done it's like a bonus.
As far as modifications go, once I get everything working as it should and fix a few small issues (worn side bolsters on the seats, the power window switch on the dash is cracked and doesn't work for the passenger side etc), I am just going to start with a Scangauge and learn how to drive it. Is there any point to lowering these cars, or are they pretty much where they should be in that department?
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
