Originally Posted by 3dplane
In these hybrids the A/C compressor is driven by a 3 phase AC motor so the compressor can still work while the car is in auto stop mode.
The windings of the AC motor is sitting inside the compressor casing with the oil in it.
If the special oil is not used, the hybrid safety circuit will detect a short to chassis ground and will disable the hybrid system (opening the contactors) to avoid any possible hazards (shocking)!
They make these things wery sensitive for safety and therefore a pain in the butt to diagnose/work on.
( I'm a dealership mechanic)
It sounds like they built the entire car around the AC system. How brilliant.
If you ever buy another Honda, make it a two-wheeled version, not four. If your wife insists on having a four wheeled Honda, just tie two Honda motorcycles together. (If it results in a divorce it will be easy to give her her half.)
