"I don't get what you folks mean about the extra H's?"
For example: Right behind your drivers side tire and in front of the door right above the crease. Look for an H. Compare the picture of your Insight to another Insight and you'll understand.
I'm trying to find the 9th one that RobertSmalls mentioned. I'm only seeing 8. I'd find 9, but you are missing one under the hood that's on the plastic engine cover that's designed to make the engine look larger than a rabbit to convince people you show the car to that it has a cylinder displacement larger than a standard sized bottle of oil.
I hope the fusebox diagram is in the owners manual or if you don't have a manual, you might want to print out the diagram of fuses. There should be a sticker on top of the bigger fusebox that is right between the drivers side strut and the coolant reservoir.
