Old 04-13-2011, 10:20 AM   #13 (permalink)
p38fln
Escape #2 - '13 Ford Escape Titanium
C-max - '17 Ford C-Max SE
It's dead on accurate in this one - if I fill up at the same gas station using the same pump handle, the fuel usage on the display matches the fuel pump exactly. It's got a returnless fuel system which probably helps with that.
Pictures of the bottom -
The large smiley hole in the bumper is for the CAC
The plastic at the top of the picture is the bottom of the air dam, below that is a piece of rubber going from the air dam to the front of the engine bay skid plate
My attempt at taking a picture of the entire bottom
Picture of it from the front - The license plate on this model is moved off to the side to allow air to pass through the bumper. If you open the hood, the radiator takes up the entire grille from top to bottom and left to right (the horizontal section is open, the vertical section is shaped like a funnel to push air into the horizontal section), with the Charge Air Cooler the width of the hole in the bumper, and in front of and below the radiator
