Thread: Engine braking
Old 04-13-2011, 11:58 AM   #13 (permalink)
Joenavy85
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
Originally Posted by Christ View Post
Most injection systems pulse/switch the ground side of the circuit (ecm input), with a constant power feed, often from some kind of distribution center.
as in they make the voltage bypass the injector? that would make no difference, since my LED is wired in parallel with the injector (to both wire leads, not just the power lead and then to ground)
