Originally Posted by Joenavy85
as in they make the voltage bypass the injector? that would make no difference, since my LED is wired in parallel with the injector (to both wire leads, not just the power lead and then to ground)
No, they have a constant single circuit, but it's pulsed on/off on the outlet side of the injector, which is connected to the ecm. I shouldn't have called it a ground, its a (-) though.
