Old 04-13-2011, 03:18 PM   #67 (permalink)
jtbo
ZX - '97 Citroen ZX Monaco
OldContinents
90 day: 61.05 mpg (US)
Originally Posted by comptiger5000 View Post
You'd probably be better off using megasquirt to implement lean burn during cruise. Cutting fuel to some cylinders won't help without a way to hold the valves open (pumping losses).
Indeed, cursed pumping losses, it would require some fabrication to have pressure relief valves or complete redesign of valve system (machinery, links and things, what is the word for those? We call it valve machinery as direct translation, but I miss proper translation).
But Megasquirt would be beneficial in many ways and from my experience it is rather easy to install, I had never soldered or modified cars before when I did one of my cars, converted from carb to megasquirt multipoint fuel injection and added later ignition control there too, found it rather easy with instructions at internet.
If added electronic throttle butterfly and Megasquirt, that would add quite amount of possibilites, limiting throttle opening to cruise by load, I think, haven't really checked up Megasquirt for years?
I would imagine that it would really help with fuel economy of such car as Crown Victoria.
