Old 04-13-2011, 04:30 PM   #44 (permalink)
old jupiter
Originally Posted by roflwaffle View Post
Kinda.... Provided there isn't excessive EGR and the mixture is homogeneous, just as much fuel should be combusted as w/o EGR.
Yes . . . because the mixture has been RICHENED somewhat to make up for what's displaced by the exhaust back-filling. One of the frequent causes of mysterious part-throttle surging is a too-lean mixture caused by excessive EGR.
There was always at least a little EGR effect in engines at part-throttle, even before the EGR system was invented, due to incomplete cylinder-filling and exhaust scavenging (especially in engines with cheap and inefficient factory exhaust and intake manifolds. This called for an earlier lighting-of-the-fire using vacuum advance.
