Thread: Engine braking
Old 04-14-2011, 08:38 AM   #34 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by justjohn View Post
I think there must be some fundamental flaw in my understanding of the system though, because rev-matching seems counter-intuitive in terms of wear to me.
It isn't, for the reasons you gave below :
"It's not using the clutch when RPMs are high that's hard on it, it's when there is a large difference between where the engine speed is and where it 'should' be for whatever gear you're going to."
Rev-matching is really necessary when you're downshifting pretty hard , i.e. when going fast.
When you're downshifting a much slower speeds, the differences in rotational speed are also lower.
Downshifting into 1st or 2nd gear however, is always best done using rev-matching, as these are very short gears.
Cause when I learned that keeping on the gas during upshifting was bad for it, I originally assumed the logical link was simply "high RPM = bad for the clutch."
The smoothest way to shift up is to reduce the throttle when upshifting, rather than cutting it, so that when the clutch re-engages, the engine turns over at the rpm it'd normally do in the next gear at that speed.
It doesn't take much gas to do so.
Essentially, it's rev-matching again.
The Following User Says Thank You to euromodder For This Useful Post:
justjohn (04-14-2011)
