Originally Posted by MN Driver
I'd find 9, but you are missing one under the hood that's on the plastic engine cover that's designed to make the engine look larger than a rabbit to convince people you show the car to that it has a cylinder displacement larger than a standard sized bottle of oil.
That engine cover is silly. The three cylinder-suggesting lumps don't even line up with the cylinders, with one of them being over by the IMA motor.
Yes, the 9th H is on the steering wheel, and I didn't count any H's that aren't legible from a few paces away.
