Check out a Mercedes 190e 2.3 or a 90s C220. These cars had a mechanical fan with electric clutch from the factory. There are many others. I replaced mine with a normal puller electric fan because it's more efficient and cheaper to replace. The electric coil is fixed on the water pump behind the fan pulley (doesn't spin).
