Old 04-14-2011, 06:33 PM   #4 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by ronhug View Post
can a run a 24 volt rated motor with 48 volts ?
Depending on the specs, maybe, most likely yes, it should have a number of ratings on the motors plate, like if it's made for intermittent use or continues use, a 24v motor that is made for continues use should be ok running for short amounts of time at a higher voltage, but if it's a light duty, low amp motor and you put it under a high load and run it at higher voltage then you will burn it up pretty quickly.
