Originally Posted by Piwoslaw
Christ, if you were to divide different numbers by the same denominator, then the function would be linear, and proportions would work. But when you divide the same numerator by different denominators the function is now rational, which is governed by its own laws. Percentiles and averages become less intuitive.
10/600=.016e
12/600=.02
11/600=.0183e
Still not linear. Did I misunderstand?
When I first noticed this, years ago, I thought it was simply because 11 is prime. So I tried this:
600/16=37.5
600/14=42.857142 (42.86)
logic suggests that the answer to 15 then should be 37+2.675871= 40.178571... But it's Not...it's just 40.
A difference of .178571. Thinking back, the difference was .45e, just a couple numbers ago...
The closer the numerator is to the denominator, the difference gets exponentially smaller.
