Originally Posted by Bigswampthing
Yeah I thought so. I may be missing some detail but they sent me a whole package of info. I'm no expert so here's what the data sheet said. The first part is for the individual cells and the second is for the whole pack. I was kinda surprised by the weight of the whole thing. Seemed really heavy. Please feel free to point out problems with this package.
Performance Data Individual Battery
Single Module Parameters U27-12XP
Module Capacity at 20Hr. Rate Ah 138.0
Module Capacity at 5Hr. Rate Ah 138.0
Module Energy at 5Hr. Rate Wh 1766
Module Nominal Voltage V 12.8
Module Charge Voltage(max) V 14.6
Module Charge Voltage(min) V 13.8
Module Discharge Cutoff V 10.0
Module Discharge Current Max Continous Amps 150.0
Module Discharge Current Max Peak (30 seconds) Amps 300.0
Module Length mm 306
Module Width mm 173
Module Height mm 225
Module Weight kg 19.5
Module Energy Density* Wh/L 148
Module Specific Energy* Wh/kg 91
Moudule Impedance mΩ 5
Total System Parameters
Modules in Series 5s
Modules in Parallel 8p
Total Number of Modules 40
System Discharge Voltage V 64.0
System Charge Voltage(max)^ V 73.0
System Charge Voltage(min)^ V 69.0
System Discharge Cutoff - Minimum V 50.0
Total Battery System Wt. kg 780
Total Battery System Vol. L 476
System Discharge Current Max Continous† Amps 1200
System Discharge Current Max Peak (30 seconds)† Amps 2400
Total Battery System Capacity* Ah 1104
Total System Energy* kWh 70.7
Discharge Profile† % DOD 100%
Utilized Battery System Capacity† Ah 1104
Utilized Battery System Energy† kWh 70.7
Recommended Controller Interface
Model Quantity
U-BMS-XP-LV, XP series BMU; 16 - 150V 1
Looking at the data sheet and reading the OP, i see a misunderstanding of battery system rating.
The battery above has a 138 AH rating. 12 of them in series will have a 138 AH rating at 144V.
He is talking about a 1000AH pack @144V
That would be 72 batteries!
The post above with a 72V 1000 AH rating would be 36 batteries. 6 series 6 parallel.
