Pretty sure factory rims are best.
I agree with Jamesqf. I've done a good bit of research on Insight wheels (going to be buying some in the coming weeks), and they're about as good as it gets. It is worth noting that the VX rims are 13" as opposed to the stock 14", and are less aerodynamic. Insight wheels give you the better gearing ratio at 14", and are nearly as good for aero as the mooncaps. Lastly, you wouldn't have much choice in 13" tires.
But hey, if you wanna sell those Insight rims, you've got a buyer right here.
Too bad I just tried to talk you out of the VX rims... Forget everything I just said! Go with the VX rims and sell the stock ones!
Hope this helps,
JMac
