Old 04-14-2011, 11:55 PM   #10 (permalink)
ngrimm
Here is what I've been doing. As mentioned above, the air dam and belly pan are one piece. The dam is 10 inches tall leaving 9 inches of ground clearance in the front. For now I think I'll cut the belly pan off about a foot behind the front tires. After the pics I used screws and washers to fasten the new air dam to the exiting small one. Not sure if I should try to angle the bottom of the dam toward the rear of the Bronco or leave it vertical. The whole thing should be easy to remove.
Name:	bedliner before cutting.jpg
ID:	8165   Click image for larger version
Name:	BroncoII front before air dam.jpg
ID:	8166   Click image for larger version
Name:	BroncoII under front.jpg
ID:	8167   Click image for larger version
Name:	BroncoII front with air dam.jpg
ID:	8168   Click image for larger version
Name:	BroncoII front side with air dam.jpg
Name:	BroncoII belly pan.jpg
