Old 04-15-2011, 04:43 AM   #13 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by ngrimm View Post
Not sure if I should try to angle the bottom of the dam toward the rear of the Bronco or leave it vertical.
Keep it vertical.
The purpose of an air dam is to reduce the amount of air going under the car - pushing the air to the sides or even over the top.
Angling the airdam to the rear will make it easier for the air to slip underneath it - exactly what you don't want.
